Re: [HSS] 29 Hudson Oil Circuit
It sounds like somebody has fiddled with the basic set-up. There are only
two pipes - one below the pump coming from the crankcase, and one above,
going to the oil pressure gauge. The oil is drawn from the sump, through the
pump and delivered internally to the pedestal, from whence it goes down
through the timing case, into the trough assembly, circulates through each
trough back to No. 6 where the remainder is flung against the side of the
crankcase and dribbles down the cut-out in the side of the rear trough and
hance back to the sump. Mains are fed by gutters in the crankcase directing
the oil to holes in the bearings. there should be nothing going to the top
tappet cover, these are oiled by the fillable resevoirs above each rocker.
The only filter is a gauze around the intake pipe. If you want I can take a
pic of my engine and email it to you.
Geoff.
Geoff.
----- Original Message -----
Sent: Friday, March 17, 2006 7:59 AM
Subject: [HSS] 29 Hudson Oil Circuit
>I am trying to figure out how my 29 Hudson lubrication works. I got
> me engine in pieces, and I'm confused about the copper lubrication
> lines.
> It looks like the oil is drawn from a (5/16"?) suction line that
> goes into the block and through a large tube in the oil collector
> pan. There is no filter on this line, it simply sucks from the
> bottom (beside the float switch).
> The pump pressure line (1/4"?) runs down the side of the head and
> then must tee off into the dash pressure gauge and also to somewhere
> on the head to lubricate the top end. (Not sure quite how this part
> works).
> Oil then flows down through the head and into the lower collector
> where the dippers fling it up. When the lower collector is full oil
> then runs into the oil pan through the screen filter.
> There also appears to be oil drippers in the top of the valve cover
> that I think would be manually filled to drop oil into the push-rod
> pivots.
> 1. Is this basically right?
> 2. Is there a drawing of all this (it is not in the manual that I
> have)?
> 3. Anyone have a picture of the oil pressure lines on the top end of
> the engine?
> jj
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
