Re: [HSS] 27 Hudson Sedan: Changing tires
Answers inserted in text below with ***
Geoff.
Geoff.
----- Original Message -----
Sent: Sunday, April 09, 2006 5:24 PM
Subject: [HSS] 27 Hudson Sedan: Changing tires
> Good day,
> Would someone kindly answer the following quesitons:
> 1. Is the correct tire size for my Hudson 550/600-19 as listed at
> Coker Tire or should I install 600-19?
****Definitely go for the 600-19, rather than the 5.50, as the latter are
usually only 4 ply rating, and small profile, which affects riding,
handling, and overall gear ratio.
> 2. My son removed the tires from our Hudson in preparation for new
> tires we plan to install. Don't chuckle too much, but after the
> tires are mounted on the split rims do they need to be balanced?
****Probably, but try the car on the road first. If you don;t have any wheel
bounce or steering wheel tremor, don't bother. If the steering wheel
shakes, you can balance the wheels yourself reasonably by loosening off the
brakes so the wheel spins totally free. Spin it lightly until it comes to
rest, and see if it "pendulums". If so, add weights on both sides at the
top of the wheel, and re-spin until the whell does not go back and forth as
it comes to rest.
> 3. It was very difficult to remove the tires from the rims. We
> ended up using large crow bars. There must be a simpler way to
> remove them. Is there?
***You can get proper rim spreaders, which wind the rim over centre for
removal of the tyres, but the easiest way if you don't have one of these is
to lever the ends up and across, so they are in a spiral, and then gently
pry off moving around the tyre. Difficult with the ridged rims Hudson used.
On your '27 Hudson the locking system should be hole and peg, and in '29
they went to a toggle lever lock.
> Thank you,
> Rick.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
