Re: [HSS] 27 Hudson (Early F Head) Engine Rebuild
I would just drop the sump, check the troughs for acid holes after sitting
for so many years, perhaps have a look at the bearings by removing each cap,
being careful not to drop or mix up the shims. Clean things up and start it
up and see how you go. I certainly wouldn't recommend stripping the engine
until you have had it running and see how it goes. It's easy enough to cut
new gasekt. Be careful with squeeze-on products, they cans shquash out and
form globules of rubbery gunk that can block up oil passages. Good luck,
Geoff.
Geoff.
----- Original Message -----
Sent: Friday, April 21, 2006 10:41 AM
Subject: [HSS] 27 Hudson (Early F Head) Engine Rebuild
> My Hudson has not been running in 10 years. Prior to that, I had the
> car started for a shor duration and it seem to run okay. (But who
> remembers after 10 years!)
> My son and I are working on the project together. He's attending a
> local junior college taking auto mechanics courses. He is wanting to
> take the engine apart to clean our any sludge etc. that may have built
> up. Quite frankly, I think he just wants us to take the car apart
> because that's what young studs want to do.
> Questions:
> 1. Should we take it apart, inspect and clean the engine prior to our
> putting it back into the car, or just put it in the car and take our
> chances.
> 2. If we take it apart, he wants to use this squeeze out of a tube
> gasket maker to replace worn gaskets. Should we or just make our own
> gaskets?
> 3. Is there someplace I can look to determine what the torque
> requirements are on the drivetrain parts....or do you just tighten
> until you think its tight enough?
> Thank you,
> Rick Gatling
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
