Re: [HSS] 27 Hudson (Early F head engine) Rocker arm bolt
It's largely a question of "If it ain't broke, don't fix it, or you're
likely to break it"!!!
As far as wire-brushing the valves and pistons, I would be careful you don't
let too much dust and rust go down the bores. Just check the rockers for
play, and if there's none, wash them off and lubricate them. the valves
would probably need lapping in at least, but check the faces for being
smooth, with no pits or burning. I can probably find you a rocker pivot if
you haven't found one already. Send your address.
Geoff.
Geoff.
----- Original Message -----
Sent: Friday, April 28, 2006 2:46 PM
Subject: [HSS] 27 Hudson (Early F head engine) Rocker arm bolt
> Hi,
> We've managed to break a rocker arm bolt for our '27 Hudson. Does
> anyone have a spare one they would be willing to sell us.
> We were attempting to take apart a rocker arm to clean when the nut
> end of the shaft broke off.
> Question: Should the rocker arms be taken apart and cleaned as we are
> doing or left alone. We have thus far wire brushed the intake and
> exhaust valves and the tops of the pistons.
> Thank you,
> Rick.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
