1927 Hudson Super Six (Early F-Head)
Good day. I hope everyone has a nice weekend. Okay, here are some
more novice questions.
1. I currently have my engine bolted to a Harbor Freight engine
stand. You know the kind, the engine is bolted to the bell housing
case and the front end hangs free. Well, in my case, the engine is
bolted to the bell housing (if that is what it is called) and is
supported on the front engine mounts by a pile of bricks on each
side. It's been that way for years now. Okay, laugh, I know. But
this was the only way I thought I could support the fron end. I
thought it would be too much weight on the rear if I did not support
the front also.
Question: Does someone have a photo of an engine stand that they
either have bought or constructed that supports the entire engine? (
I am taking a mig welding class and this would be a good project if
someone had a good design.
2. Follow-up from an earlier question. On the top end of the engine
(looking straight down at the pistons) there are two holes that I will
be fitting with 1 5/16" discs cemented in using permatex and a slight
tap with a ball pean (sp.= pean?) hammer.
Question: Why would the manufacturer cast an engine with freeze plug
holes on the top of the engine since there are freeze plugs cast on
the end of the motor? (Just curious?) Or were these vent holes from
sand casting?
Rick and Son
the front also.
sand casting?
Rick and Son
