Re: [HSS] 1927 Hudson Super Six (Early F-Head)
I don't know the answer, but I assume they were holes for the sand casting,
as that is the only reason for so-called frost plugs anyway, as a way to
remove the sand from the castings. They do have to filled in though.
Geoff.
Geoff.
----- Original Message -----
Sent: Sunday, May 07, 2006 1:15 AM
Subject: [HSS] 1927 Hudson Super Six (Early F-Head)
> Good day. I hope everyone has a nice weekend. Okay, here are some
> more novice questions.
> 1. I currently have my engine bolted to a Harbor Freight engine
> stand. You know the kind, the engine is bolted to the bell housing
> case and the front end hangs free. Well, in my case, the engine is
> bolted to the bell housing (if that is what it is called) and is
> supported on the front engine mounts by a pile of bricks on each
> side. It's been that way for years now. Okay, laugh, I know. But
> this was the only way I thought I could support the fron end. I
> thought it would be too much weight on the rear if I did not support
> the front also.
> Question: Does someone have a photo of an engine stand that they
> either have bought or constructed that supports the entire engine? (
> I am taking a mig welding class and this would be a good project if
> someone had a good design.
> 2. Follow-up from an earlier question. On the top end of the engine
> (looking straight down at the pistons) there are two holes that I will
> be fitting with 1 5/16" discs cemented in using permatex and a slight
> tap with a ball pean (sp.= pean?) hammer.
> Question: Why would the manufacturer cast an engine with freeze plug
> holes on the top of the engine since there are freeze plugs cast on
> the end of the motor? (Just curious?) Or were these vent holes from
> sand casting?
> Thanks,
> Rick and Son
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
