Re: [HSS] Generator,Cutout ?
The cut-out is simply a relay which closes the contacts once the generator
starts charging, and opens them again when it stops charging. Obvoiusly
something has been changed when you put the new cables in. The circuit is
quite simple - the wire from the cut-out goes up to the ammeter. I
suggest you disconnect the generator drive coupling, remove the cut-out lid,
and manually close the points. The generator should spin and show about 4
amps discharge. If not ,then you have to double-check that field fuse. If
okay, then take the cut-out right off, and connect the wire from the
ammeter directly to the wire that comes out of the generator. If the
generator now spins, then the cut-out is faulty. If it doesn't, your
generator is crook. Good luck,
Geoff.
Geoff.
----- Original Message -----
Sent: Monday, May 22, 2006 2:27 PM
Subject: [HSS] Generator,Cutout ?
>I just changed my old original battery cables to 3/0 copper with new
>soldered ends and a heavy duty cut off switch. I put a good charge on the
>battery and now it seems the amp meter does not show charge all the time
>like before. I turn the lights on and it goes to discharge but for the
>little while I ran her she never went up to the charge like before. I
>checked the fuse on the gen. and it is good. Does the cutout turn off and
>on like a switch as far as charge and not charge ?? Or maybe something went
>wrong when I did this ? Thanks Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
