Re: [HSS] Generator Fuse ?
Yes, turning the battery off before killing the ignition would have caused
a large increase of current through the field coils. I'm not sure what
rating the fuse should be, but there is not a huge current going through the
coils, so you should be okay with 7.5 amp.
Geoff.
Geoff.
----- Original Message -----
Sent: Wednesday, May 24, 2006 5:21 AM
Subject: [HSS] Generator Fuse ?
> Thanks Geoff it was the fuse. I thought I checked it good first time
> around but I did not. Put a new 7 1/2 amp.? (That what was in there) and
> it came back to life. Is this the right amp size ? I installed a battery
> cutoff switch between the battery and the starter and I turned the cutoff
> switch off before I turned the ignition off. Maybe the cause of the fuse
> blowing trying to run the car from the generator only ? I have seen a
> little cover that covers the fuse on other generators but mine is gone. If
> anyone has one to sell please let me know. Thanks Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
