Re: [HSS] Rearend ?
Fill to the level of the plug in the rear cover. Your pinion seal is
leaking, you iwll have to take it out and fit a modern seal, or else pack
around the outer edge of the original felt to shrink it down a size. The
large nut and lock nut are for adjusting the pinion bearings. I have the
workshop manual for the '26 models, which are identical in this department,
but different in the brakes. Let me know if you want a copy.
Geoff.
Geoff.
----- Original Message -----
Sent: Monday, June 05, 2006 8:29 AM
Subject: [HSS] Rearend ?
In the 1929 Hudson Instruction book it says to fill with oil up to the pipe
plug. Is this the pipe plug on the rear or the one that is in the front that
is a "L" with a pipe plug on the top ? This one seems like it would be to
much oil? I also have alot of oil getting thown from where the drive line
goes into the rearend while driving and leaking a little when parked. I see
what looks to be some type of a large ajustment nut in that area and not
sure what it does ? Is there any repair manuals out there that covers all
this stuff ? I see manuals but seem to go back to the 40s and maybe a little
30s. Also what weight gear oil ? Thanks Ron
Community email addresses:
Post message: HudsonSuperSix16-29@onelist.com
Subscribe: HudsonSuperSix16-29-subscribe@onelist.com
Unsubscribe: HudsonSuperSix16-29-unsubscribe@onelist.com
List owner: HudsonSuperSix16-29-owner@onelist.com
Shortcut URL to this page:
http://www.onelist.com/community/HudsonSuperSix16-29
Yahoo! Groups Links
