Re: [HSS] Ignition help
In a message dated 7/12/06 10:06:20 AM, john@carneyconsulting.com writes:
to want to idle smoothly. I have to keep the fast idle up, and just
can't seem to get it to run.
I had a similar problem with my '26. The motor has a '29 Distributor mounted on it and just wouldn't run sweetly. It was hard starting and lacked power. Geoff puzzled over this some time checking timing, vacuum leaks and other things. Finally he noticed that the points were wrong. After filing the rubbing block down to size, the car started easily and runs happily.
Paul O'Neil
SoCal
1926 Hudson Anderson Coupe
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in here?)
www.cichet.us
www.aeromark.net
