Re: [HSS] Starting A 1929 Hudson Or ?
You are pretty well on the button Ron. My '29's have always been the same -
retard the spark,open the hand throttle a whisker, full choke for a couple
of winds, push the choke in half way, and it fires straight away. Advance
the spark, leave the choke out about half for while until it warms up, push
in, and then forget about it for the rest of the day's motoring. Leaving the
choke out partly when cold leaves the fast-idle port open. Push it right in
once you get under way, or leave it out if it tends to spit back at you.
Certainly, never wind the motor over for long with the choke right out, as
this sucks vast amounts of fuel into the engine.
Geoff.
Geoff.
----- Original Message -----
Sent: Friday, August 04, 2006 2:26 PM
Subject: [HSS] Starting A 1929 Hudson Or ?
> Back when I got my 29 Hudson and first got her running after about 11
> years of sitting I would choke her to death with gas all over and her
> flooded. Since I got her on the road again I have been reading ways that
> people here and other sites have started there old cars. Now when she is
> cold (Southern Californaia) I pull the choke to full let her turn over a
> coupe of times and push the choke in. Fires right up. When she has been
> run no choke at all and she fires right up. When I drive her around and
> stop for a little bit its like a guessing game, choke or not to choke is
> the question but for me and I try no choke first and if no fire I pull it
> out for a second. The old guy I bought my 29 from said that it smoked alot
> and he parked her for 11 years when I took her home. I put ATF in the
> cylinders just incase I had a siezing problem because I was told ATF had
> alot of detergent for breaking down carbon and it worked I guess.When I
> first got her fired up it smoked like hell, oil among other things in the
> cylinders. It cleared up and since then no smoke and runs great. Fixing
> some oil leakes at the moment but doing good clearing them up with some
> great help here. Good luck and think of it as a hobby, I do, Ron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.394 / Virus Database: 268.10.5/407 - Release Date: 03/08/06
