Re: [HSS] 27-29 Carbs
The '27 and '28 carbs and hot box can be interchanged directly to a '29, but
the carb will face the opposite way. You cannot bolt them directly to a '29
hot box without making up an adapter plate, as the bolt patterns are
different, and the early carbs don't have the fast-idle bypass. You can
use an earlier float bowl, but the high speed needle is on the inside, so
you have to make up a link to operate it from the inside of the throttle
shaft, which means disconnecting the compensating mechanism for the exhaust
bypass flapper.
Geoff.
bypass flapper.
Geoff.
----- Original Message -----
Sent: Thursday, August 10, 2006 2:38 PM
Subject: [HSS] 27-29 Carbs
> Any of you Husonites know if a 27 Marvel VB-10-661 is a bolt on
> option(if one can be found)
> I understand the 28 VB -10-669 is a bolt on.
> Are the bore sizes the same on the 27 and 28 carbs as the 29?
> Dreaming of a road worthy 29 Hudson Rumble Seat Coupe, Tim Gruner
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.405 / Virus Database: 268.10.8/415 - Release Date: 09/08/06
