Re: [HSS] Re: 27-29 Carbs
Attachments :
Hi, John Meadows has repro carb bowl and covers for the Marvet Model
E carburetor used on the 1929 Hudson cast out of silicone bronze. I have
one on my 29 and what a difference. No more pot metal leaks,no more epoxy
sealer, no more cracks. It took a little fitting and tweaking. It's really
great that he took the time to have these cast out of a material that won't
disintigrate and crumble away like the originals did.
Ed Moore
----- Original Message -----
Sent: Friday, August 11, 2006 7:30
PM
PM
Subject: [HSS] Re: 27-29 Carbs
james would you happen to have a carb bowl for a marvel model v?
In HudsonSuperSix16- 29@yahoogroups. com,
"James Coats"
<jamcoats@.. .> wrote:
Tim,
> Do you have a carburetor at all? I have a few Marvel parts, if
you
> have anything to start with we might can get you going.
> Best Regards,
> James Coats
> - In HudsonSuperSix16- 29@yahoogroups. com,
"old29hudson"
> <old29hudson@ > wrote:
> Any of you Husonites know if a 27 Marvel VB-10-661 is a bolt on
> option(if one can be found)
> > I understand the
28 VB -10-669 is a bolt on.
> > Are the bore sizes the
same on the 27 and 28 carbs as the 29?
> > Dreaming of
a road worthy 29 Hudson Rumble Seat Coupe, Tim Gruner
