A Couple Of ??
I am getting a oil leak from around where the adjustment plate bolts to the motor where you can adjust the timing chain. I had this apart many years ago when I had the water pump/generator shaft out for repair and not sure if there is some type of seal in there ? Please advise. And, what size wire to use to replace the charging wires from the generator to amp meter to battery ? Thanks, Ron
