Re: [HSS] wheels
This will only temporarily cure the problem, as soon as it dries out again
the spokes will start to work. You have to dismantle the wheel, that is ,
undo the centre hub bolts, take out the spokes, cut shims to fit over the
end, and re-assemble. I'm preparing an article for the W.T.N. on this
technique. Wood wheels are the same as wires - each spoke has to be tight
to carry it's share of the load. the spokes wedge against each other in
the centre, and shimming the outer ends tightens this wedge. Make sure you
nimber the spoke and holes, as you havone only one chance in 479,001,600 in
getting them back in the correct order.
Geoff.
Geoff.
----- Original Message -----
Sent: Wednesday, November 01, 2006 5:04 PM
Subject: [HSS] wheels
> just thinking about the wood spoke's has anyone ever had to tighten
> the spokes? there is one spare wheel that is loose in the rim. shouls
> a little rain do the trick or wood oil seem to me that they need to
> swell up a bit.
> thanks from dan/karen
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.1.409 / Virus Database: 268.13.21/509 - Release Date: 31/10/06
