Re: [HSS] Part Castings & Steering column brackets
James, I don;t see how you are going to be able to mount the brackets
without taking the wheel off, as where the arm clamps in the upper will
also have to be split. I still have the mold for getting new bronze
brackets cast. Not trying to put you off of course, but I have difficulty
envisaging how it will work.
Geoff.
Geoff.
----- Original Message -----
Sent: Saturday, November 18, 2006 12:27 PM
Subject: [HSS] Part Castings & Steering column brackets
> Gang,
> There are some members on this list that have had replacement parts
> cast as-needed for certain things. I'd like to hear some input and
> kick around the idea of having both the spare tire hold-down arms and
> the crank hole covers cast. Those of you who have had parts
> reproduced, what are your thoughts? I will buy at least three
> hold-down arms and at least one (most likely two) crank hole covers.
> On the flipside, I am currently having NEW STEERING COLUMN BRACKETS
> manufactured out of billet aluminum. These will be cut out of billet
> stock by water-jet and machined to resemble the originals. For mine,
> I am probably going to make it so it can be installed without taking
> the column apart, by doing something like splitting the entire lower
> loop into two halves instead of just at the bottom edge. However I
> will be able to supply them finished and un-cut so you can do
> whatever. Let me get these out of the shop and I will post pictures.
> Best Regards,
> James Coats
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.430 / Virus Database: 268.14.7/537 - Release Date: 17/11/2006
> 5:56 p.m.
