Re: [HSS] Re: Help - Lewis Mendenhall
I have replaced the inlet valves, but never the guides. Surprisingly, in
spite of the rather inadequate lubrication of the upper valve chamber, there
is usually little wear in the guides. However, if there was wear, I agree
that a modern bronze guide liner should do the job fine. It's a different
story however with the exhaust guides. Use bronze liners in these and you
have to allow a good .005" clearance otherwise the valve stems will jam up,
particularly if you are using stainless valves.
Geoff.
Geoff.
----- Original Message -----
Sent: Saturday, November 25, 2006 1:38 PM
Subject: [HSS] Re: Help - Lewis Mendenhall
> JJ,
> Egge Machine sells the exhaust guides, and stainless valves. Last I
> checked the valves are $20.40 each, intake and exhaust, and the
> exhaust guides are $27.20 each. I haven't ever taken the intake
> valves out of an F-head Hudson so I can't tell you what's in there,
> but perhaps a standard sized bronze guide liner from your cylinder
> head shop would be in order? Maybe Geoff can comment.
> Best Regards,
> James Coats
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.430 / Virus Database: 268.14.15/550 - Release Date:
> 24/11/2006 5:20 p.m.
