Re: [HSS] 1927 Hudson F Head Motor bolt
The engine mount bolts ae designed to allow the spring to compress if the
chassis is under extreme twisting stress. Early problems with the Super Six
and Essex Fours, with the left leg of the crankcase breaking off, so the
spring-mounted bolts were installed. The correct installation is to
install the spring on the bolt, and insert through the chassis mount and
crankcase leg from underneath. Install a washer and the castellated nut,
screw down until the slack is taken up and compress the spring by
tightening about one turn on the nut, then install a split pin to stop it
from undoing.
Geoff.
from undoing.
Geoff.
----- Original Message -----
Sent: Thursday, February 22, 2007 3:38 PM
Subject: [HSS] 1927 Hudson 'F Head' Motor bolt
> Would someone please explain the proper sequence for installing a front
> motor bolt (with spring and washer) on my early 1927 'F Head' engine.
> See the following quesitons:
> 1. Question: Is the spring installed onto the front motot bolt
> followed by the washer (lip side facing spring) or is the washer placed
> on first?
> 2. Question: Is the front motor bolt installed up through the bottom
> of the frame, then through the motor mount and secured by a king nut
> and cotter pin?
> Thanks,
> Rick.
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups - Join or create groups, clubs, forums & communities.
> Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.441 / Virus Database: 268.18.3/696 - Release Date: 21/02/2007
> 3:19 p.m.
- 105 Essex Super 6
