27 Hudson F Head Valve Adjustment
The novice is back. Help please. I recently had our intake and
exhaust valves and seats ground. I have adjusted the exhaust valves
using the following method:
Exhaust Valve adjustment
1) Bring intake valve rod to top by turning over crank.
2) Adjust exhaust valve clearance to .014
Note: This adjustment is a cold adjustment and I was told that once
the engine is fired up I would then reset the adjustment between .06-
.08.
I recently read a page from "Everyman's Guide to Motor Efficency",
which was published in 1927. In part it states the following: "Adjust
the lifters while the engine is hot, if possible. It this cannot
convenienetly be done for any reason, leave two or three times the
normal space in the adjusting the cold engine, and then test the
adjustment when the engine is good and hot."
Comments please.
Intake Valve Adjustment
I currently have the head off. What would be the recommended method of
adjusting the intake valves. As an example, would I watch the exjaust
valve raise from the seat fully and then make the adjustment or?
Thank you.
.08.
Comments please.
Thank you.
