27 Gasket Question
Hi Geoff,
Thank you for the information on my 27 Head gasket. I asked Geoff a
question regarding a recent post regarding the head gaskets I
uploaded to "Files". Here was his response, which I think novices
like me would appreciate knowing:
Regarding the extra gasket I was told was a '27, Geoff wrote:
"Okay, the gasket is for a 1916 to 1926 Side Valve Super six."
Regarding the fitup of the washers I installed, Geoff wrote:
"The brass washers will be fine like they are, the head will locate
them..."
Regarding the small tear in the '27 head gasket, he wrote:
"...and you will have no problems with that slight tear in the
gasket, as it is a position where there is no danger of leakage of
water or compression. Give the gasket a good coat of aluminium
paint before you install it, and let it set so that it is semi-hard
before fitting. Tighten the head bolts to 50 lbs maximum, bring the
motor up to normal temp and then re-torque the head
nuts again. best wishes,
Geoff."
Thank you Geoff.
Question:
1) Is there any special aluminium paint that I use or just any can of
aluminium spraya paint will do?
2) What does the aluminium paint do for the gasket?
Thanks again,
Rick Gatling
them..."
Geoff."
Thank you Geoff.
Question:
Thanks again,
Rick Gatling
