Re: [HSS] 27 Gasket Question
High temp engine paint is probably better, but any type is okay really. A
spray can of paint is easier, and gives a more even coverage, without
inducing runs around the holes. The metal flakes in the paint fill any
imperfections in the gasket, head, and block surfaces.
----- Original Message -----
Sent: Monday, April 09, 2007 8:02 AM
Subject: [HSS] 27 Gasket Question
> Hi Geoff,
> Thank you for the information on my 27 Head gasket. I asked Geoff a
> question regarding a recent post regarding the head gaskets I
> uploaded to "Files". Here was his response, which I think novices
> like me would appreciate knowing:
> Regarding the extra gasket I was told was a '27, Geoff wrote:
> "Okay, the gasket is for a 1916 to 1926 Side Valve Super six."
> Regarding the fitup of the washers I installed, Geoff wrote:
> "The brass washers will be fine like they are, the head will locate
> them..."
> Regarding the small tear in the '27 head gasket, he wrote:
> "...and you will have no problems with that slight tear in the
> gasket, as it is a position where there is no danger of leakage of
> water or compression. Give the gasket a good coat of aluminium
> paint before you install it, and let it set so that it is semi-hard
> before fitting. Tighten the head bolts to 50 lbs maximum, bring the
> motor up to normal temp and then re-torque the head
> nuts again. best wishes,
> Geoff."
> Thank you Geoff.
> Question:
> 1) Is there any special aluminium paint that I use or just any can of
> aluminium spraya paint will do?
> 2) What does the aluminium paint do for the gasket?
> Thanks again,
> Rick Gatling
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.446 / Virus Database: 269.0.0/751 - Release Date: 7/04/2007
> 10:57 p.m.
