1921 Hudson and Gruss shocks
The new owner of the 1921 Hudson phaeton asked about
the Gruss shocks and the "firm" ride. I had the
privilege of riding many hours in that car while Bill
owned it. The ride is pretty much typical of Hudsons
of that era. This car may seem stiff because there is
a extra set of friction type shock absorbers mounted
under the rear of the car. Those really work as they
prevent nasty air-borne activities when you go over a
hump or railroad tracks too fast.
Regarding the Gruss shocks...they are worthless on
todays modern roads. On old dirt roads when you
didn't travel fast and could lower their pressure,
they probably worked well. On modern highways and the
speed that car can sustain, it is best to keep them
pumped up to 70 to 80 pounds pressure. There are two
reasons for that: First, if you let the pressure down
in the Gruss shocks, the tires WILL rub against the
tops of the fenders and could get hot enough to ruin
the paint. Second, low pressure will allow the car to
heave over in a corner as the shock on one side
compresses and the one on the other side unloads. To
add air, unscrew the silver acorn shaped cap on top of
the Gruss shock and there is a schraeder valve under
it. This is a great touring car!!
____________________________________________________________________________________
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives.
http://tools.search.yahoo.com/toolbar/features/mail/
