Re: [HSS] Hudson 1928 Super-six "Piston Rings"
Hi Enrique
Egge Machine (you can find them on the internet)
has most of the engine parts for these cars, including rings, pistons, pins,
valves, guides, timing chains, etc. You may want to check your pistons and
bores before you go ahead. Just fitting rings will not do much good if
your bores are tapered or the ring lands are worn on your pistons.
Karl
----- Original Message -----
Sent: Monday, April 09, 2007 11:38
AM
AM
Subject: [HSS] Hudson 1928 Super-six
"Piston Rings"
"Piston Rings"
Hi Hudsoners: Please inform me where I can
get a new set of Piston Rings for my 1928 Hudson Super-Six.
Regards, Enrique
