Carbon Removal Questions
Good day Everyone,
I (novice) have been reading "Everyman's Guide to Motor Efficiency",
first published in 1921. This copy is from 1927. Actually pretty
interesting reading. Here is some of what it says about "carbon
removal".
"Removing Carbon with Kerosene". "About once a week if the car is
used a great deal, put a couple of tablespoons of kerosene into each
cylinder through the relief-cock or spark plug hole while the engine
is hot-just after stopping. Let the engien stand overnight. When it
is started up in the morning the carbon wil blow out, the kerosene,
vaporized by the heat, soaking into it and loosenig it up. If the
deposit is an old one the same process will help, and repeated
applications will get rid of a good deal, but not all of it."
"Removing Carbon with Denatured Alcohol". One of the best carbon
removers is denatured alcohol. It will often do remarkably good work
and will not affect the cylinder walls, pistons or rings. It will
free the piston rings if they have become gummed in their groovea and
so possibly improve compression somewhat."
It goes on to say "Alcohol can be used in the same way as kerosene,
though more of it should be used, as it evaporates rapidly. To do a
thorough job, however, proceed as follows:
Bring one or more pistons, according to the number of cylinders in
the engine, to the top of the compression stroke. Both valves will
be closed at this point. Fill the combusion chamber full of
denatured alcohol through any opening, and then close it up leaving
no way of escape. Let it soak for not less than six hours. Treat
each cylinder in turn. When all have been treated, run the engine to
blow out the carbon."
It goes on further to say, "Run the engine with adulterated oil for a
short time. The alchol is a cleaner and willl give the engine a good
washing out. Then throw away the oil and put in fresh.
To keep the engine clean, put from two to four ounces of alcohol,
depending upon the cyulinder size into each cylinder every three or
four days, while the engine is hot. Be sure that all openings are
closed. Of course it is impossible to have all the valves closed at
the same time, but the cylinder that have valves open one day should
be treated with valves closed the next time, and son on."
"Removing Carbon with Water". "Run the engine at fairly high speed
and while running feed water in through the air intake of the
carburetor. Give the engine all the water it will take without
losing much speed. A great deal of carbon may be losened and blown
out in this way. When getting rid of carbon by these and similar
methods run with the muffler cut-out open to keep carbon from
clogging the muffler. Run the engine for a few minutes after the
carbon has stopped coming through to make sure that everything had
been blown out."
Questions:
1) What do you think of these methods of cleaning out carbon?
2) What is a "relief cock"? (See Removing Carbon with Kerosene)
3) What is a muffler cutout? (See Removing Carbon with Water
Thank you,
Rick Gatling)
removal".
been blown out."
Questions:
Thank you,
Rick Gatling)
