Fan Belt Length
Hi, do any of you know the correct length of the flat fan belts used
on the earlier Hudsons? I can see that it is fairly critical as if
too long the fan hits the top tank and much shorter it will hit the
radiator shell. My fan is the six bladed type with an outer ring and
bicycle type ball bearing hub. Looks like I could put the car in
neutral and rev the engine and drive it with the fan!
Thanks, Karl
Thanks, Karl
