Fw: CAMSHAFT THRUST
Attachments :
Hi Ted
I am sorry I did not send this earlier but after your reminder guilt set in
and here it is. As Geoff says, nominal thickness is .085". The purpose of
this thickness is to ensure alignment of the timing chain with all of its
sprockets. I have specified 14 ga as this is the closest commonly
available. 13 ga is closer but I think this is an oddball.
After you get this made, carefull pry the camshaft out from the block about
3/16". Any more and some cam followers will fall off the cams and you will
have a major headache. Slide the forked piece I have drawn in from the
opposite side from the dowel pin to ensure it fits over the camshaft
journal. The dimensions I have given should give you about .010" clearance.
Once you are sure it fits OK over the journal, slide it in from the correct
side and drop the hole over the dowel pin. If it does not want to go file
the dowel pin a bit shorter. Do NOT pull the camshaft out further.
I have extra oil slingers and the necessary spacers if you cannot find any.
I also have extra timing chain covers ( and a new felt seal) should you be
doubtful about your modified cover. I have never had a problem with leakage
with the original setup.
Re: water pump and shaft. The screwed on arangement I described earlier
takes up no space. It is simply a stainless steel shaft screwed onto the
stub of the original. What you saw in the photos I sent is not a coupling,
but the housing for a carbon/ceramic inner seal.
Hope this helps.
Karl
Hope this helps.
Karl
----- Original Message -----
To: "Karl Home" <karlh@cablelan.net>
Sent: Monday, June 04, 2007 3:35 PM
Subject: CAMSHAFT THRUST
> Hamson Engineering
> PO Box 128
> Pender Island BC
> V0N 2M0
> 250.629.6119
> http://www.hamsonengineering.com
> Internal Virus Database is out-of-date.
> Checked by AVG Free Edition.
> Version: 7.5.446 / Virus Database: 269.5.4/768 - Release Date: 4/19/2007
> 5:32 AM
