Re: [HSS] A Very Nice Trip/Bad Gas?
Attachments :
Paul, I reckon it could be dirty gas, rather than
"bad". It only takes a litlle amount of grit to cause the piston
inside the carburettor to stick slightly, and this could have been your
problem. Otherwise it could have been a heat problem. I
suggest you discard the hot-air pipe from the carb, and get as much cold air as
possible in there. As far as the wheels are concerned, I have outlined how
to fix them. Do you want me to comoe over and do them??? Best
wishes to all,
wishes to all,
Geoff.
----- Original Message -----
Sent: Friday, June 22, 2007 9:06 AM
Subject: [HSS] A Very Nice Trip/Bad
Gas?
Gas?
Hudson Anderson Coup
