Re: [HSS] Messing with 1929 Hudson Timing Chain
I couldn't open the link to your pics, but to remove the water pump and
shaft assembly you need to remove the timing chain, by taking off the cam
sprocket. then undo the three bolts holding the rear flange of the adusting
assembly into the crankcase, and slide the whole assembly out the back.
Then you can operate on the water pump. Probably the shaft has seized in
the bushing. Don't try and drive the front pin out with the assembly in
place. Get back to me on geoffclark@xtra.co.nz if you need any specific
help.
Geoff.
help.
Geoff.
----- Original Message -----
Sent: Thursday, August 09, 2007 6:24 AM
Subject: [HSS] Messing with 1929 Hudson Timing Chain
> Here are two close up (and large) pictures of my timing belt and
> gear. It looks like I need to pound the pin out of the oil/water
> pump/generator drive shaft.
> http://209.234.75.36/share/1929_Hudson/29Hudenginetiminggear/Timing%
> What I am worried about is if the shaft is siezed up in the water
> pump, how do I get it broken loose to get it to come out. Are there
> any other issues I need to watch out for when removing the shaft?
> Notice how pitted the shaft is after the second packing nut.
> http://209.234.75.36/share/1929_Hudson/29Hudenginetiminggear/Engineri
> ***If the links in the post are broken apart, copy and paste the
> entire link through .jpg into your browser.
> Aaron Cooper
> Central Iowa HET
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.476 / Virus Database: 269.11.8/941 - Release Date: 7/08/2007
> 4:06 p.m.
