More help on 1929 Hudson Town Sedan
I am progressing on going through the externals on the engine.
I was successfull in getting the accessory shaft off the side of the
motor.
http://209.234.75.36/share/1929_Hudson/1929Hudsonenginepics/Work200708
10/Engineright.JPG
***If this link gets split in post, block and copy the entire line
from "http" through ".jpg" and paste into your brower and it will
open***
The new "look" of the front:
10/1929Hudsonfront3.JPG
Close up:
10/Notiminggear.JPG
I still cannot get the generator collar off the end of the shaft. I
heated the collar up until it was glowing red and it did not move an
inch.
10/Pumpshaft.JPG
I am taking it to a machinist friend of mine and seeing if he can
press it out. I will probably have him make me a new shaft.
I was attempting to take the starter off, I removed the hold down
strap, un-bolted the solenoid but I cannot get the starter out.
Before I really started prying on it, is there something I am
missing. The body will spin back and forth but the gears won't seem
to pull out. Any advice?
If anyone has a engine manual electronically, that would help.
A thanks to Sheldon Rody for a sending me a care package of "stuff"
and information to help move me along.
Aaron
Central Iowa HET
motor.
10/Engineright.JPG
open***
Close up:
10/Notiminggear.JPG
inch.
10/Pumpshaft.JPG
Aaron
Central Iowa HET
