Re: [HSS] More help on 1929 Hudson Town Sedan
Re the starter - you have undone the nut which connects it to the switch???
You need to undo this, twist the starter body around until it disengages
from the slot, and the starter will then just slide forward. You will hae
to use a puller on the generator collar. Don't use too much heat, you will
cook the bearing.
Geoff.
cook the bearing.
Geoff.
----- Original Message -----
Sent: Sunday, August 12, 2007 2:28 AM
Subject: [HSS] More help on 1929 Hudson Town Sedan
>I am progressing on going through the externals on the engine.
> I was successfull in getting the accessory shaft off the side of the
> motor.
> http://209.234.75.36/share/1929_Hudson/1929Hudsonenginepics/Work200708
> 10/Engineright.JPG
> ***If this link gets split in post, block and copy the entire line
> from "http" through ".jpg" and paste into your brower and it will
> open***
> The new "look" of the front:
> 10/1929Hudsonfront3.JPG
> Close up:
> 10/Notiminggear.JPG
> I still cannot get the generator collar off the end of the shaft. I
> heated the collar up until it was glowing red and it did not move an
> inch.
> 10/Pumpshaft.JPG
> I am taking it to a machinist friend of mine and seeing if he can
> press it out. I will probably have him make me a new shaft.
> I was attempting to take the starter off, I removed the hold down
> strap, un-bolted the solenoid but I cannot get the starter out.
> Before I really started prying on it, is there something I am
> missing. The body will spin back and forth but the gears won't seem
> to pull out. Any advice?
> If anyone has a engine manual electronically, that would help.
> A thanks to Sheldon Rody for a sending me a care package of "stuff"
> and information to help move me along.
> Aaron
> Central Iowa HET
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.476 / Virus Database: 269.11.13/946 - Release Date:
> 10/08/2007 3:50 p.m.
