Assessory (pump) Shaft Woes
I need some help. Having some real trouble disassembling the
assessory shaft. Does anyone have an exploded view of the entire
assessory shaft? Before I go breaking it I thought it might be nice
to have an idea what is supposed to come apart.
Once you have the timing chain gear off the end, have taken off the
springs and bolts how do you get the end piece off? Here is where I
am at:
http://209.234.75.36/share/1929_Hudson/1929Hudsonenginepics/Work200708
11/TimingGearEnd.JPG
***If this link is broken in the post, block the entire line
from "http" to ".jpg" and paste into your browser and it will open***
How is the distributor gear attached to the shaft? Is it a part of
the shaft or a collar? Does it slide out the front. I tried pounding
it forward, but didn't want to get out the big stick until I was sure.
11/DistributorGear.JPG
How does the pump impeller attach to the shaft? It appears that it
was pinned, but I think this one is sheared off.
11/PumpImpeller.JPG
I tried heating it up, but it would not budge.
Anyone have extra parts? Not sure these are going to make it. : )
If anyone has an exploded view of the assessory shaft I would be
indebted to you. Also any advice would also be appreciated.
Aaron
am at:
11/PumpImpeller.JPG
Aaron
