Re: [HSS] Assessory (pump) Shaft Woes
I have the detailed instructions from the workshop manual if you want them
photocopied and posted. Other comments inserted in text below.
Geoff.
Geoff.
----- Original Message -----
Sent: Sunday, August 12, 2007 12:46 PM
Subject: [HSS] Assessory (pump) Shaft Woes
>I need some help. Having some real trouble disassembling the
> assessory shaft. Does anyone have an exploded view of the entire
> assessory shaft? Before I go breaking it I thought it might be nice
> to have an idea what is supposed to come apart.
> Once you have the timing chain gear off the end, have taken off the
> springs and bolts how do you get the end piece off? Here is where I
> am at:
> http://209.234.75.36/share/1929_Hudson/1929Hudsonenginepics/Work200708
> 11/TimingGearEnd.JPG
> ***If this link is broken in the post, block the entire line
> from "http" to ".jpg" and paste into your browser and it will open***
> How is the distributor gear attached to the shaft? Is it a part of
> the shaft or a collar? Does it slide out the front. I tried pounding
> it forward, but didn't want to get out the big stick until I was sure.
!!!!The gear is part of the shaft. there is a collar forward of this, the
shaft has to driven backwards from the eccentric body.
> 11/DistributorGear.JPG
> How does the pump impeller attach to the shaft? It appears that it
> was pinned, but I think this one is sheared off.
!!!!The impeller is originally pinned to the shaft, and driven by a woodruff
key. these are not uncommonly worn beyond re-use. you can drill and tap
the impeller and use two stainless grub screws, which bitie into the shaft.
Use two in line.
> 11/PumpImpeller.JPG
> I tried heating it up, but it would not budge.
> Anyone have extra parts? Not sure these are going to make it. : )
> If anyone has an exploded view of the assessory shaft I would be
> indebted to you. Also any advice would also be appreciated.
> Aaron
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.476 / Virus Database: 269.11.13/947 - Release Date:
> 11/08/2007 2:29 p.m.
