Troubleshooting the starter
Everything is going well with getting my 29 Town Sedan back on the
road. The engine is all back together, repaird accessory shaft in
place.
I am having an issue with the starter. Nothing happens when I push
the starter pedal. When I bridge across from the battery connection
to the starter post, it spins just fine. When I have my kid push
the pedal and I bridge across, it will turn the engine over, but
then when I remove the bridge, the pedal sticks, the engine keeps
turning over and I have to go pull it off the floor. Here are my
assumptions:
1. The post that bridges the contacts under the starter, is not
making good contact (I did clean it).
2. When I bridge across with the pedal pushed down, it forces the
current through the poor connection.
3. I am missing a spring/the spring is not strong enough to pull the
pedal back to disengage the small drive gear.
Any thoughts on how to make the starter work better? Should I
squeeze the contacts together or coat them with something?
Aaron
place.
assumptions:
Aaron
