One more time - Fuel Sending Units
I was talking with my car buddies. I was lamenting the pains in
trying to get a fuel sending unit without haveing to pay $175 to get
the original redone. One of my buddies said I should just use the
VDO sending units that have a 10 -180 OHM range and then just switch
the leads on the back of the fuel gauge. Looking at the wiring
diagram, it does look like I could do that. Any thoughts?
Another interesting note on VDO lever type sending units states "if
the fuel gauge reads backwards, but accurate, the float arm has been
installed from left to right into the pivot. Reinstall from right
to left." I am going to try and install it "incorrectly" and see if
it will work with my gauge.
Also I found a handy list of Fuel Sending ohm ranges.
Brand Empty (Ohms) Full (ohms)
VDO Lever Arm 10 180
Stewart Warner 240 33
GM from 65 0 90
GM pre 65 0 30
Ford pre 90 73 10
VDO tube type 60-90 0
Aaron Cooper
1929 Hudson Town Sedan
1946 Hudson Pickup
GM from 65 0 90
GM pre 65 0 30
Ford pre 90 73 10
Aaron Cooper
1946 Hudson Pickup
