Re: [HSS] One more time - Fuel Sending Units
There is no way you can switch the leads on the back of the gauge - one
receives voltage from the ignition switch, and the other goes to the
connecting switch for the sump and tank. if the gauge reads backwards it is
just a case of getting the float to swing the other way by bending the arm
around 180 deg. Any 180 ohm rheostat whould work with a reasonable amount
of accuracy - after all, you don;t really need to know how many gallons
exactly you have in the tank, just so it registers empty tank just before
the tank actually runs dry. Mine read 7/8 at full, and starts t flicker
below 1/4 full, so I know it's time to head to the gas station. Good
luck,
Geoff.
luck,
Geoff.
----- Original Message -----
Sent: Tuesday, September 11, 2007 8:59 AM
Subject: [HSS] One more time - Fuel Sending Units
>I was talking with my car buddies. I was lamenting the pains in
> trying to get a fuel sending unit without haveing to pay $175 to get
> the original redone. One of my buddies said I should just use the
> VDO sending units that have a 10 -180 OHM range and then just switch
> the leads on the back of the fuel gauge. Looking at the wiring
> diagram, it does look like I could do that. Any thoughts?
> Another interesting note on VDO lever type sending units states "if
> the fuel gauge reads backwards, but accurate, the float arm has been
> installed from left to right into the pivot. Reinstall from right
> to left." I am going to try and install it "incorrectly" and see if
> it will work with my gauge.
> Also I found a handy list of Fuel Sending ohm ranges.
> Brand Empty (Ohms) Full (ohms)
> VDO Lever Arm 10 180
> Stewart Warner 240 33
> GM from 65 0 90
> GM pre 65 0 30
> Ford pre 90 73 10
> VDO tube type 60-90 0
> Aaron Cooper
> 1929 Hudson Town Sedan
> 1946 Hudson Pickup
> Community email addresses:
> Shortcut URL to this page:
> Yahoo! Groups Links
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.485 / Virus Database: 269.13.14/999 - Release Date:
> 10/09/2007 5:43 p.m.
