23 Hudson: heart attack averted.
After about half an hour of running time on a fresh engine, I noticed
that there were oil leaks from around the pan gasket. Investigation
found several loose bolts. I snugged them up and started the engine
to check for leaks. BANG BANG BANG BANG!!! Shut it off quick and go
back to he house feeling pretty discouraged. If one rod bearing
failed so soon how were the rest going to fare?
This morning off with the pan to inspect the damage. My 23 pan had
had a severely damaged trough section so I had removed it entirely and
used a 29 trough section which is, of course, a separate piece and
makes cleaning the pan out much easier.
The earlier connecting rods are a little bigger to accomodate the
bronze backed shell bearings. Turns out that after I snugged the pan
bolts up, the castellated nuts on the rods 3 AND 4 could just catch
the lip of one of the diverter channels, folding it down so it really
hit. Easily fixed by bending the diverter channel up so it would
clear. All's well that ends well.
Karl
Karl
