Re: [HSS] Bad Day
Aaron, I have a spare block or two. I would
have to check the bores, etc. Where are you located? I am in British
Columbia.
Columbia.
Karl
----- Original Message -----
Sent: Saturday, September 15, 2007 6:22
AM
AM
Subject: [HSS] Bad Day
Well I got the head of my 29 and yep there was just a little water in
the cylinder. Upon further inspection there was a small pin size hole
in the side of the cylinder that went right through into the water
jacket. Not a very happy moment. So the next step is getting the
cylinder block off the crankcase and having a machine shop measure to
see that I don't have other cylinders with thin walls.
As a back
up plan, does anyone know of an old block laying around that
could be
purchased? I realize that I might have the same issues with
another one,
but I am not sure that sleeving a number of cylinders is
as good as
finding an original to either clean up and use or bore out.
Anyone else
had to put a sleeve in their F-head?
Aaron
