What to do about temperature gauge for 1929
Just a little update on my 1929 Hudson Town Sedan. Everything is
off down to the crankcase. Need to pull the transmission, and plan
on removing crankcase turning over and inspecting all the bearings
as well as clean it up. There is a lot of gunky oil in the
crankcase.
I hope to get the cylinder and head down to shop to boil it out. In
the next week I hope to get the sleeves in cylinder 3 and 4. I did
get a lot of the rust out on my own with a air hose and vaccuum. I
was amazed at how thoroughly the holes between the block and head
were blocked up. The two dollar sized holes were completely filled
and took a hammer to break through. The eight quarter-sized holes
required a drill, and all the small holes around the perimeter
needed to be drilled out as well. I made the assumption that all
the water holes should be the same size as holes through the head
gasket. If anyone knows of any restrictors that may have been used,
I would be interested in knowing.
One thing that pains me is that I broke the engine temp sensor that
goes into the back left side of the block. The tube was fine all
the way down to the engine, but the brass fitting would not come out
so I could get the bulb out. After breaking the tuble, I got the
big nut off the engine, drilled out the brass fitting and recovered
the bulb. Does anyone know how to fix? Is it possible to refill
and re-attache the bulb so the gauge works? Is there anyone who
repairs these? Or do I have to stick a Turkey thermometer in the
side? : )
Another question that came up, if I have to re-sleeve more than one
piston, is there a benefit to sleeving all and replacing with modern
pistons? Anyone done this before?
Aaron
1946 Hudson Pickup
Central Iowa
crankcase.
side? : )
Aaron
1946 Hudson Pickup
Central Iowa
