Interesting article on F-Head history
I always am amazed at what you find on the internet. Found an
interesting piece on I.o.E engines (Inlet over Exhaust)
Found it here:
http://www.morganownersclub.com.au/technical%20talk.htm
The Coventry Climax IOE Engine
(WHATMOUGH PATENTS AND OTHER MATTERS)
Submitted by John Merton
The Coventry Climax I.o.E., or rather O.I.S.E. (overhead inlet, side
exhaust valve) engine used in early production Morgan four-wheelers
has a number of Great Britain patents listed on a plate on one
rocker cover. These, ascribed to Whatmough (Wilfred Ambrose
Whatmough) are numbers 303592, 319810, 326454, 329340, 332523,
349460, and 373991. They date from around January 1929 to May 1930.
My interest in the above patents grew out of a statement in a book
that the cylinder head was manufactured to a patented design by
Whatmough. With little previous interest in or knowledge of the
origins of the I.o.E design, I (and friends I spoke to on the
matter) assumed that Whatmough had invented the I.o.E configuration,
as it was the essential feature of the cylinder head design.
Subsequently, an Australian historical automotive journal of good
standing carried an article on Hudsons intimating that Hudson had
invented the "F"-head design. This claim had been included in a
1928 advertisement for Hudson cars.
The matter triggered an examination solely to see, initially, which
of the two had the stronger claims to having invented the I.o.E
design.
The outcome follows. It has led into fields much wider than just
patents, and challenges and refutes entrenched Morgan lore in a
number of areas.
For much of the information on the Triumph connection (or more
properly lack thereof as regards the particular engine used in
Morgans) my thanks to Antony (Tony) Cook, founder and past
secretary of the Pre-1940 Triumph owners' Club of the UK, and
currently secretary of the Skoda and Tatra register in Australia.
BACKGROUND - the Hudson and Whatmough patents.
First, neither Whatmough nor Hudson invented or patented the I.o.E.
design.
I.o.E. engines date almost to the dawn of motoring. The earliest
tended to have "atmospheric" or "automatic" inlet valve operation,
based on the principle that gravity would assist the valve opening
process. Royce and Rolls-Royce cars before the "Silver Ghost"
(except the V8 "Legalimit") had I.o.E. engines, and they were well-
established motor cycle practice by around 1910.
Significant is their appearance in Hudson's light car, the "Essex",
named after an English county, which had a four cylinder I.o.E.
engine from around 1919 on, and was apparently quite a well-known
sight on English roads in the 1920's. These cars were assembled for
a time at a plant on the Great West Road, Chiswick. Another make to
use I.o.E engines in the 1920's was Humber.
In January 1928, Hudson was granted a patent (US1656051, inventor
Stephen I Fekete) for refinements to the I.o.E design. The essence
of this patent, which covered the arrangement of valves, head,
cylinder and spark plug, was an inlet valve overlapping both piston
and exhaust valve , so that cooler inlet gases could help cool the
heads of the exhaust valves while still efficiently entering the
combustion chamber. The arrangement aimed at greater volumetric
efficiency, higher compression without pre-ignition, higher rpm and
more power, while still providing effective exhaust valve cooling.
The Patent also provided for spark plug location adjacent to the
exhaust valve on the side furthest away from the piston, to spread
the flame progressively from the hottest to the coolest part of the
chamber, helping prevent pre-ignition.
Hudson itself used a six-cylinder I.o.E. engine to this design for
about three years in the late 1920's, but later abandoned this in
favour of side valve designs. It was the smooth running of these
later engines which made such a big impression on Rolls-Royce
engineers in the 1930's.
The listed Whatmough patents cover, with a single exception,
combustion chamber design, aimed at gas- flow, turbulence, and
volumetric efficiency considerations. While their listing on the
valve cover might imply they are only cylinder head related, they
also embrace gas-flow considerations affecting the cylinder block on
engines with side exhaust valves. Whatmough played around with
curvilinear shapes (including relieving the bore) moving later to
squaring off some faces in the interests of manufacturing
convenience, the clear implication being that some of his theories
didn't amount to much if anything in actual practice!
Some Climax engine valve covers also carry a plate
stating "Whatmough Cylinder Head", leading to speculation that he
may himself have manufactured these heads and supplied them to
Coventry Climax. The patent changes taken in the light of
manufacturing experience tend to give some credibility to this
speculation.
Basically these patents (except for the one) mostly relate to the
first, involving modifications or improvements to it. A common
thread is location of the spark plug over or adjacent to the
exhaust valve on the side away from the piston, for the reasons
stated in Hudson's earlier patent! It is almost certain that
Whatmough knew of the Hudson and other work in this field at the
time. "Motor Sport's" William Boddy, and others have indicated
quite a lively correspondence at the time in automotive engineering
journals between Whatmough and Weslake (perhaps also Ricardo - these
touted as the "big three'' of cylinder head design, at least in the
UK), concerning their particular theories.
Whatmough's patents are catholic in relation to valve
configuration, the principles seen as applicable to side, T-head,
and I.o.E., with one patent also specifying O.H.V. In other words,
the patents listed on the valve cover of the Coventry Climax I.o.E.
engine are not specifically directed at an I.o.E. cylinder head
configuration.
The "exception" patent, number 332523, was for cooling passages,
the idea being that if adequate cooling was provided for the "hot"
part of the engine, i.e. the exhaust side, the inlet side would be
overcooled, and vice-versa. Whatmough's approach, basically, was to
provide for larger water passages on the exhaust side and smaller
ones on the inlet side. Once again, this patent covers both
cylinder head and block.
Found it here:
design.
number of areas.
design.
speculation.
configuration.
