J B Weld and block repair
I have used J B Weld and found it an effecive repair. It keeps my
Hudson running well. J B Weld would be effective on an external
crack.
However as this is an internal repair and no for sure way of
monitering for a leak, welding should be done. Welding may cause
more problems as the block is old and deteriated. In other words a
small hole developes on the block while welding will turn into a big
one during the welding process. The heat will burn away bad parts and
you may have a larger area to repair. I had a professional welder
repair a cracked heat tube and he had a 2 in hole to fill because of
degradeation.
Also would not use antifreeze in this engine as it will ruin any
bearing surfaces it comes in contact with. Water only, and I would
do many heat cycles with side cover off before trusting this repair.
Also suggest using an internal block sealer that is avaible at auto
parts stores to repair from the inside of this area.
Sheldon Rody
1929 Hudson Victoria
crack.
degradeation.
Sheldon Rody
