re re re driving
This is most likely old hat for most. Since there's been little
responce to "Driving" let me inject a little of my own experience of
operating several pre 1930 hudsons over the last 20 years. First a
word about preparing your car for driving; "Brakes" I hear folks say
that one can't drive 2 or 4 wheel mechanical brakes cars at speed
with modern traffic; Nonsense. If adjusted properly and if the
correct soft woven shoe material is used along with proper braking
procedure ie- if you start to skid let up and reapply pressure as
needed, they stop quite well. Another falsehood is that 6volt: clean
all grounds well then coat them with grease or other protective
coating make shure electical items (starter etc.) are in good working
order. I use 50 candle power headlight bulbs and run them all night
with stock generator charging just fine. Good grounds or lack of will
make or break a 6 volt system. Make shure your spokes are tight, if
not soak, shim and seal them. Wood spoke wheels are quite safe at
highway speeds if in proper shape. When driving do not be afriad to
use quadrant and dash controls(a must for good driving) ie adjust
spark advance for high speed.Slightly retard for hills,power, and to
reduce ping/knock. Lean mixture at steady long high speed runs on
flat roads/ richer for low speed and hills and city traffic. too lean
in traffic will cause overheating, be shure to remove the two block
water resistors washers for hot weather and replace in winter if you
live in extreme conditions- this will keep engine cool in summer and
warm in winter.a misconception is that these help in spreading
circlation throughout engine to keep engine cool:not so!see hudson
service manual for overheating woes. I am starting to see double so
all for now ---Mike
all for now ---Mike
