Stupidist thing I have ever done!
I had replaced the leaking headgasket and changed the oil on my 1952
Hudson Hornet. After some driving it was time to retorque the cylinder
head bolts. I took off the air cleaners and loosened all the
headbolts thinking I would then retorque them in order.
Suddenly POP! WHOOSH! and coolant was flowing out everywhere.
As all the headbolts were loose the coolant in the head dumped into
the cylinders and into the pan as well as outside the engine.
Hey I was only a teenager, I didn't yet know the headbolts should be
loosened and tightened one at a time.
I took most of the afternoon to clean the mess and change oil and
replace the headgasket.
Also in this era I tried for a week to fit a exhaust pipe and could
not make it fit ,untill I finally turned it end to end, and it then fit
fine
Hey on that others helped and could not figure that one out too!
Sheldon Rody
1929 Hudson Victoria
fine
Sheldon Rody
