Sidemount tyre strap
The tyre buckle is 2 in wide at end with roller, it tapers and end at
belt is 1 7/8 . From the roller across the buckle to other side it is
2 in.
See in Hemmings or internet, there is a 'Buckle man"
Lots of curves on the buckle, will email you a pic if you want to
send to the buckle man or check with a harness maker.
The belt from where it folds over the buckle is 30 1/4 to pointed end.
It is 1 3/8 wide. On the backside where the belt folds over the
buckle it is 3 in long with 4 brass rivits and the belt loop held
between the three rivits. The belt loop is 3/4 wide.
The first hole is 3 in from tip , with holes every inch with a total
of 7 holes. The belt thickness is 1/4 or slightly less.
Probably the orginal leather was a pink colored pigskin. The problem wi
with that is in time it will turn black and stain whitesidewall tyres.
My leather maker used a leather that was dyed a brown color and it is
coated so it will not change colors or stain, your harness maker will
know what it is. If not let me know.
Would suggest checking measurements of sidemount arm where belt goes
thru before ordering.
Sheldon Rody
1929 Hudson Victoria
2 in.
Sheldon Rody
