Sidemount mirror strap dimensions
The mirror straps dimensions are as follows
The strap is 3/4 in wide 1/8 thick
From the buckle loop is 31 inches to the tapered end
The first hole from the tapered end is 6 in and there are 9 holes
which are 5/8 apart on center
The belt loop is 3/4 wide and is held between two rivits
the buckle is 1 3/8 wide with a roller. The buckle is stamped 'England"
Sheldon Rody
1929 Hudson Victoria
Sheldon Rody
