Trouble shooting my 29 Hudson
I thought I would bounce my issues with my 29 off the group. I have
two main issues.
Issue 1: The first is that I am running rich at idle and then loose
power on flat roads at about 40 mph and then on hills I drop down to
25-30 mph. I drove it almost a 100 miles this weekend. After
talking with others, they did not think I was running rich (no black
exhaust) at higher speeds. At idle, I have quite a bit of black
smoke at idle. If my car is backed up to my garage, my tail pipe
leaves a nice "shot gun blast" of black gas.
Here is my plan, I am thinking about reducing my idle and high speed
jet (filling with silver solder and redrilling. My big question is
how much? Is there any other reason I would be running so rich?
I stopped several times to either screw in or out my adjustment
screw on the carburator and in both situations, the carburator
started "coughing/blowing" out the carb. It ran the best when the
screw was even with the top of the adjustment guide.
Could timing contribute significantly to it running rich? I am not
quite sure I have got my timing nailed down since when I manually
advance, my engine runs worse at higher speeds.
Issue 2: My second issue is with my brakes. I have both front
wheels adjusted so they light rub on the brake pads when the car is
jacked up and you spin them (both are the same). I have the left
rod tightened all the way down and I still pull hard to the right.
If I tighten the drum down on the left side I am worried I will
excessively wear the brake pads. It doesn't appear I that I can
adjust the rods any more at the bar. Any thoughts?
I am finally at the point where I am working on all these small
issues. A couple others I am looking at:
My tappet covers wind up with oil dripping out of them. I have them
tight, but should I use a layer of silicon on them to seal better?
Is it possible that it is coming out of the air vent on the back
cover?
I still need to follow Geoff's advice on adjusting my steering, but
that is down on the priority list.
Thanks for any information anyone can provide.
Aaron Cooper
1929 Hudson Town Sedan
1946 and 47 Hudson Pickups
two main issues.
cover?
Aaron Cooper
