Continued help troubleshooting 29 Hudson
Ok, I am still haveing the same issue with my 29. At high RPMs my
29 starts missing badly. In 3rd gear I can go 42mph and still run
smoothly. Between 42 and 45, my engine starts missing badly and I
cannot go over 45.
1. The engine is timed correctly and advance or retarding the spark
does not help.
2. It has a new timing chain installed. - Question, should there be
any rotational movement in the shaft? Should there be any end play?
3. The engine has new sparkplugs, new wires, new rotor, new cap.
4. The carb does not leak at all, has has been rebuilt several
times.
Questions:
Should I check and see if the distributor needs to be rebuilt? I
have about 1/8 inch rotational movement of the shaft. Should I
tighten the chain until there is no play?
Since it happens at the same RPM no matter what gear, I would think
it would be one of two things:
1. At that RPM, my gas is somehow constrained and the car goes lean.
2. My distributer is worn and goes out of time at that RPM.
Thoughts?
Aaron Cooper
1929 Hudson Town Sedan
1946/7 Hudson Pickups
cannot go over 45.
does not help.
times.
Questions:
Thoughts?
Aaron Cooper
