Early 27 F Head Engine Rebuild
Good day from the novice,
At present, the valve cover, side panel engine cover, and the oil pan
are off. The timing chain has been removed. The water pump,
ecentric and generator shaft have also been removed. The distirbutor
has been pulled. (I had the eccentric renewed because it was in such
poor shape.)
Would someone please explain the following procedure:
1) According the 27 manual in order to replace the timing chain, I
need to first turn the camshaft until the exhaust valve has closed
and the intake valve is about to open on the #6 cylinder. I must
also turn the crank so the #1 and #6 are TDC.
a. How do I perform this task and know that the exhaust valve is
closed and the intake is about to open.
b. How do I determine that the number 1 and 6 pistion are at
TDC. Do I look through the spark plug hole?
thank you,
Rick G.
poor shape.)
thank you,
Rick G.
