Re:
Anthony, in addition to what the others have said
it may be a good idea to check out your starter switch arangement which is under
the starter. This tends to get dirty and oil covered over time and cause
starting problems.
starting problems.
Karl
----- Original Message -----
Gene
Birdsall
Gene
Birdsall
Sent: Monday, May 04, 2009 6:19 AM
Subject: RE: [HSS]
Anthony, These 6 volt systems are adequate if they are kept up to snuff. As David said, make sure your cables are of the correct size. I bought my #1 cable from a local welding store. Or call Dave Kostansek in the club roster. He can make one up for you. Make sure all connections are clean and tight. Buy a battery with the highest cca (cold cranking amps) you can get. Mine is 800, and works well. I think it cost about $80.00 from NAPA. Another thing to try is, keeping the battery on a continuous charge with a trickle charger. If a car sits for several days, or weeks, a battery can lose some of its charge faster than you may think. Leaving you with a weak battery to try and start you car. Gene.
--- On Mon, 5/4/09, David Young <David@websters. co.nz> wrote: From: David |
