Re: S/S Head Pics. [1 Attachment]
Hi
----- Original Message -----
Karl Hamson
Karl Hamson
Sent: Friday, May 22, 2009 2:26 PM
Subject: Re: [HSS] S/S Head Pics. [1
Attachment]
Attachment]
John, As Geoff says, that is a low
compression head. The attached photo is of a high compression head from
a 1920 car in Argentina. You can see there is a considerable difference
in combustion chamber shape..In my view, we most certainly should be using a
high compression head ( or even higher?) if we are going to go to all that
work to develop and reproduce something. In the meantime, I thank you
for your efforts and count me in for an aluminum head if you get this off the
ground.
ground.
Karl
----- Original Message -----From: John
MeadowsSent: Thursday, May 21, 2009 4:37
PMSubject: [HSS] S/S Head Pics. [3
Attachments]
Have attached some photo's of an old
26 head that was cracked which I cut in half to check the material
thicknessbetween the combustion chamber and waterjacket.
(see the drilled holes).
