Fw: [HSS] Seal Cork Float?
#ygrps-yiv-101039899 .ygrps-yiv-101039899ygrp-photo-title {
TEXT-ALIGN:center;WIDTH:75px;HEIGHT:15px;CLEAR:both;FONT-SIZE:smaller;OVERFLOW:hidden;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899ygrp-photo {
BORDER-BOTTOM:black 1px solid;BORDER-LEFT:black 1px solid;BACKGROUND-COLOR:white;WIDTH:62px;BACKGROUND-REPEAT:no-repeat;BACKGROUND-POSITION:center 50%;HEIGHT:62px;BORDER-TOP:black 1px solid;BORDER-RIGHT:black 1px solid;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899photo-title A {
TEXT-DECORATION:none;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899photo-title A:active {
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899photo-title A:hover {
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899photo-title A:visited {
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899attach-table DIV.ygrps-yiv-101039899attach-row {
CLEAR:both;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899attach-table DIV.ygrps-yiv-101039899attach-row DIV {
FLOAT:left;}
#ygrps-yiv-101039899 P {
PADDING-BOTTOM:3px;PADDING-LEFT:0px;PADDING-RIGHT:0px;CLEAR:both;OVERFLOW:hidden;PADDING-TOP:15px;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899ygrp-file {
WIDTH:30px;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899attach-table DIV.ygrps-yiv-101039899attach-row DIV DIV A {
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899attach-table DIV.ygrps-yiv-101039899attach-row DIV DIV SPAN {
FONT-WEIGHT:normal;}
#ygrps-yiv-101039899 DIV.ygrps-yiv-101039899ygrp-file-title {
FONT-WEIGHT:bold;}
CLEAR:both;}
FLOAT:left;}
WIDTH:30px;}
FONT-WEIGHT:bold;}
In the process of getting the old '29 ready for the
Muckenthaler car show in just a few weeks time, some long delayed work has been
getting done. One of the issues is the Marvel Air Valve carby. (BTW, does anyone
have a quick plain English explanation of how these devils work? What does the
air valve do?)
Picking up the thread from two years ago, the carb would
flood after sitting some time and drip gas all over the ground. I had taken to
turning off the gas feed from the vacuum tank every time the motor was stopped
to prevent this.
The advise was to lap in the seat and if there was still
flooding, lower the float level. To pursue this I removed the carby to have a
good look-see. Lapping in that seat is going to be a challenge as the needle has
nothing to hold on to with a ball socket on the top preventing rotation. I was
able to roll it around some and possibly this will make some
difference.
Something unexpected was teeny-tiny bits of the cork float
all over the float chamber. A Look at the float itself showed that it was
largely intact but showing some signs of delamination. A reseal of some sort is
in order! The new fuel we are getting is full of toxic stuff that make many
older paints & varnishes fail. All I can think of that might work is gas
tank sealer sold in quart cans to line the inside of rusted tanks. I have used
this stuff in the past to seal vacuum tanks with good results.
The cork
float ought to benefit from a dip or two in the gas tank sealer as well. If I
use this stuff, will it add weight to the float resulting in a higher float
lever? Or, will it make to old porous float more buoyant and reduce the float
level?
What have you used successfully to reseal these cork
floats?
Paul O'Neil
SoCal
1923 Ford Model T
Runabout
1926 Hudson Anderson Coup
